If I have a toll free Canada wide plan and I'm going from Montreal to Toronto, do I have to pay extra per call made? need to know tonight :)
I have a toll free canada plan from Montreal, I am going to Toronto tommorrow, will roaming fees apply or am I allowed to call to Canada wide with no extra charge? thanks I need to know tonight
Userlevel 2
Yes. Unless Your plan is NOT unlim, but after 6 or 7pm, then after using your Min, There is a fee
I'm sorry but that's not correct. Evening and weekends vary depending on what plan you have but there is NEVER a roaming fee on a Canada wide plan as long as you're in Canada. Per minute charges only apply after the anytime minutes are exhausted but even then it's a standard rate without long distance charges as long as you're calling From Canada to Canada
I have an unlimited calling plan... So that means I don't pay a cent correct?
If you have unlimited minutes then you won't pay a cent extra as long as you're calling from Canada to Canada. I'm a trucker and use my Koodo unlimited plan across Canada, never extra charges ever.
Alright that's great news thx! How bout ur 3G can u use Canada wide or it will cost me a crapload extra...
Canada Wide means all of Canada. Canada is your Zone. Enjoy your zone of Canada. If you are in Canada that means you're covered. Period. I'm in Cornwall Ontario but I live in Magog, QC and I have a QC phone number from Sherbrooke. I use my phone and data all over Canada. Because I have a Canada Wide Plan, there are never extra charges.
Wow it's a 2 in 1. I can use data and call while getting there! Thank you, is there anything else I should be aware of?
The cake is a lie!
And... What else?
In Breaking Bad, everytime Walt kills someone, he absorbs their mannerisms.
Ok....
Hello Eli
As long as you have a Canada Wide plan there will be no extra fees to call in Canada. You'll only use up your airtime minutes as you would have in your town!
Robert wrote:
Hello Eli
As long as you have a Canada Wide plan there will be no extra fees to call in Canada. ...
I don't have minutes, I have unlimited call in text canada wide. so ur saying no extra charge correct? even if my plan is from Montreal? juts trying to make sure. thanks again
Robert wrote:
Hello Eli
If you have unlimited minutes, then no extra charge yeah!
Robert wrote:
Hello Eli
So roaming charges don't apply... Are you 100% sure?
Robert wrote:
Hello Eli
Canada wide means all of Canada, there are no roaming charges or extra fees within Canada.,
Robert wrote:
Hello Eli
Ok so I will use my phone to call to Canada... Thx for ur help Are you sure there r no roaming charges?
Robert wrote:
Hello Eli
Straight from El Tabador:
http://help.koodomobile.com/plans-add...
Robert wrote:
Hello Eli
Thx man! Appreciate you helping me now I can make calls!!!
Userlevel 3
If your plan includes unlimited text messaging Canada wide there is no extra charge. For example you send a text from Montreal to someone in Vancouver, Winnipeg, Toronto there will not be extra charges. If your visiting Vancouver, other cities, sending a text to someone in Montreal there is no extra charge.  If your plan includes Canada wide minutes (voice calls,) it's the same thing. No matter where you are in Canada, you won't be charged extra or long distance for calling someone anywhere in our country. If you have a prepaid plan you will need to buy talk boosters to make voice calls Canada wide. Except for the $50 prepaid which has unlimited Canada wide minutes. I hope this helped! :)
It did thx a lot!
