If a phone plan says unlimited evenings and weekends, wouldn't one assume that means phone and data? It really doesn't specify.
Hi Lou Lou, It may not specify it at first glance, but if you look at the plan descriptions, you see a little "1" next to it and when you read the nitty gritty section under the 1, it does specify that it is calling.
Mathieu wrote:
Hi Lou Lou, It may not specify it at first glance, but if you look at the plan descriptions, y...
Thanks!  That darn nitty gritty.  Thankfully no harm done.
