I threw up on my phone....any idea how to clean it....I am pretty sure that I cant wash it, except that its already wet. Please help me.
  • 11 May 2015
  • 795 views
(empty)
Wipe with damp cloth. Clean with alcohol wipes. Try not to do this again.
Also, put phone in a bag of rice. Should help the drying process.
Thank you both
Let it in the rice for at least 24 hours before opening it
You can also get electronic wipes which are basically like alcohol wipes, I've actually got some at the dollar store before so they're not expensive
Yikes! Well here is what you could do: Clean the phone up first. Remove the battery inside of the phone (if there is any). Keep the battery away from any liquids. Then use rubbing alcohol to clean up the phone. Use the electronic wipes and try to use rubbing alcohol all over again. Then in order to make the phone smell nice, try to use some sort of a smelling liquid (like perfume or cologne) to remove the smell. Afterwards wipe the battery clean and place it in it's original place (if you have to). Otherwise well..... You might have to replace the battery (or the phone if it is damaged from liquids).
