I need to make a call overseas how much will I be charged ?
I need to make a call from Canada to Brazil
$0.50/min or with the $2/month long distance saver add on it will be a cheaper rate. Go check it out since my page is loading extremely slow: http://help.koodomobile.com/coverage-long-distance-and-travelling/long-distance
Dennis wrote:
$0.50/min or with the $2/month long distance saver add on it will be a cheaper rate. Go check ...
My page is loading slow too Must be something wrong with the website. I have been waiting for it too load for 10 minutes.
Userlevel 3
Yes the site is running super slow and timing out.
Userlevel 2
Checked from FireFox, and yup,it's taking longer than 10 seconds.
If you call or receive international calls you must have the $2 per month add-on for this. The add-on is not a saver it just gives you the right to make int'l calls.Then check the rate for the country you wish to call. I have found that their rates are extremely good. I pay $0.03/ a minute to Australia.
Userlevel 4
Dian wrote:
If you call or receive international calls you must have the $2 per month add-on for this. The ad...
Umm...that's not right at all. The LD saver actually does lower the per minute rate for calling
