i need help to figure this out
i cannot send pic msgs with my new phn, texts are ok, but pic msg are not going thru. i have unlimited text/pic msgn on my acct, so i dont know why this is happening
Did you request a data block on your account Sheila? If you did, that is why it's not working. The multimedia part of an MMS needs the data channel to remain open for the data bits to go thru. Yes, it's annoying, but there ain't much you can do short of asking for the block to be removed and then managing/turning off data yourself from your device. Sorry 😞
thanks for the advice, David... lol after i posted the question, i figured it out... just a little hiccup is all lol
Sheila Westling wrote:
thanks for the advice, David... lol after i posted the question, i figured it out... just a litt...
You tagged android so you may want to check out the Google play store for a firewall. With that you can keep other apps from using data unless you're on wifi. If you do decide to use one please report back with success or failure story. Tks
(Stole from chad) Using your Picture Messaging without allowing access to Mobile Data by anything else. Brought to you by: The Koodo Mobile Masters with special thanks to Kid Android and Timo Tuokkola. Can you send regular text messages but not picture messages? SIM CARD BASED phones require a data connection in order to send those messages. So if you have data turned off, or blocked, these messages won't go through. "But wait" you say "My plan includes unlimited text and picture messaging. I want to use it but I don't want data because I feel it's too expensive (or whatever)". The Mobile Masters have your solution below. You can enable data by navigating Settings / Wireless and networking / Mobile Network Make sure 'use packet data' or 'enable data' is checked. If you have data blocked by Koodo you'll need to unblock it. You'll have to call customer service to have the block removed. Follow the methods below to ensure data is only available to picture messaging. Setting up A Koodo phone for MMS with no additional Data Access FOR ANDROID DEVICES -=- for iphone 3GS see Note 2 First We need to do a little housekeeping. Navigate to your current messaging app and delete any picuture message you previously tried to send but have failed. Next: Navigate to Settings / Wireless controls / Mobile networks / access point names METHOD 1. Find the Koodo.sp Apn and tap it to open it. Some phones will allow you to edit this APN, for those phones which will not allow you to edit the default APN (I.E the Samsung Galaxy S2x), please skip to Method 2. Tap APN type and change it so it reads only "mms" then tap the menu key and select save APN once saved the 4g indicator should disappear. Please see: Note 1 METHOD 2 You'll be creating two APN's Add the first apn (usually by hitting the menu key and tapping ADD NEW) Note: in the example below please omit the spaces between the http: and the address This is done because some websites shorten URL's Input the following settings (leaving designated fields blank): APN NAME: Koodo (NoData) APN: spp.koodo.com Proxy server: Port: Username: Password: Server: MMSC: Proxy server: Port: MCC : MNC : APN type : default For APN Type we use "default" for this example but if it doesn't work for you, go back and change it to "Internet" Save this entry (usually by hitting the menu key and selecting SAVE) Now create a Second APN using the following settings APN Name: Koodo MMS ALLOW APN: sp.koodo.com Proxy server: 74.49.0.18 Port: 80 Username: Password: Server: MMSC: http: //aliasredirect.net/proxy/koodo/mmsc Proxy server: 74.49.0.18 Port: 80 MCC : 302 MNC : 220 APN type :mms Now save this entry as you did the first. On the list of available Access Point Names you'll notice three (or more) entries. Select the Koodo (NoDATA) APN and make it active (you'll notice you can not choose the Koodo MMS ALLOW entry) Exit the APN menu. Reboot the phone (Shut it off and turn it back on) Turn off your WiFi Open your browser and attempt to access any webpage other than Google (google is normally cached). You should get a message that the page cannot be displayed. Note 1: (For Everyone to read) You'll notice the 3G or 4G data indicator has disappeared leaving only the Signal strength indicator. IF YOU HAD PREVIOUSLY TRIED AND FAILED TO SEND PICTURES IT MAY TAKE A FEW MINUTES FOR THE INDICATOR TO DISAPPEAR. When you do send a picture the Data indicator will re-appear and the picture should be sent. The Same thing will happen when you get a picture message. Note 2: (iPhone 3Gs) Apparently the APN is not easly configurable. You may need to be Jail Broken and download an APP called "Tetherme" which will allow you to edit the APN as per Method 2 (Thanks DJMcPimpin's Sister)
Userlevel 2
B2theden wrote:
(Stole from chad) Using your Picture Messaging without allowing access to Mobile Data by anyth...
She said she figured it out....
holy that's long. um gj
No need to copy just paste a link. Thanks for da props
