I migrated to the $60 plan. My phones are working, but the data is not !! Please help !
60$ plan data not working
Hi Malcolm,
Have you checked if your mobile data was set to ON and the APN was set to https://www.koodomobile.com/help/setting-data-your-non-koodo-phone
I would also suggest you reset the network settings, restart your phone and see if it helps.
Dinh wrote:
Hi Malcolm,
Have you checked if your mobile data was set to ON and the APN was set to [url=https:...
Thank you so much Azure123. It was a non koodo phone and I followed the instructions and now it is working ! Thank you again. Much appreciated 🙂
Dinh wrote:
Hi Malcolm,
Glad it helped you!
Cheers
