I'm planning on buying a Japanese cellphone. Will it work with Koodo?
I'm planning on buying the AU KDDI LG LGV31 Isai VL (G3)
However, I've been told that Japanese cellphones work only on certain frequencies. This is what is written on the website for this phone:
2G Network : GSM GPRS EDGE  850, 900, 1800, 1900 MHz
4G Network : LTE 800, 1500, 1800, 2100 Mhz
CDMA2000 Network : 800. 2100 Mhz
Should I be ok?
  • Here's the website page if you need more info.
  • http://www.kyoex.com/au-kddi-lg-lgv31-isai-vl-g3-3gb-ram-ver-high-spec-4k-2k-smartphone-unlocked/
  • 2 replies
    This device is missing the frequencies used by Koodo. It won't work.
    Ok thank you. That's what I thought
