I'm going to Cuba and I don't want to be changed with with roaming charges
Hi Richard,
If you just want to use your phone on wifi or to take pictures I would suggest one of the two options:
  1. Take your SIM card out of your phone. Just make sure you don't loose it so you can put it back when you return to Canada
  2. Put your phone into air plane mode and turn on Wi-Fi manually.
The resort has wifi and I will buy a card for wifi all I want to do is FaceTime with my children
Then what Mathieu suggested will do just that! You won't get charged on either one of his options.
