I'm cruising to hawaii. will there be extra roaming charges at sea?
samsung android phone with canada wide plan sailing from vancouver to hawaii. will the temporary add-on roaming feature be enough?
There are no roaming packages for shipboard roaming. You will pay their extortionate per minute rates until you get to Hawaii where any US roaming package that meets your needs will work.
I suggest planning for other means to connect with your loved ones, and others while you are at sea.
thanks!
