i keep turning on my bluetooth but it keeps turning off and not finding any devices to connect with i have a motorola g4 phone
each time i turn on bluetooth it says it is disabled i have the motorola g4 phone it used to connect before but now doesn't work after updating
Make sure that no power saving mode is enabled. Start by turning the Bluetooth on your device off and back on again. If the problem continues, clear the cache for Bluetooth by going to the Bluetooth Settings. Restart the phone after clearing the data and cache. Source: http://www.androidauthority.com/lg-g4-problems-fixes-621631/amp/
Ok mine does the same.  Im glad its not just my phone.  I am going to call them today to see what they can do.  If i hear anything i will let you know
Pierre Larocque wrote:
Ok mine does the same.  Im glad its not just my phone.  I am going to call them today t...
Also found this.
Nope still no bluetooth
i turn bluetooth on then more settings and its says off i switch to on but the circle wont light up it swipes over but nothing happens.  Your update broke my new phone.  I need bluetooth its an important feature on the phone
it's not Koodo's update that broke the phone.
Try the following steps
Go into:
  • Settings
  • Google
  • Security
  • turn off Google Play Protect
Go back into:
  • Settings
  • Applications
  • click on the 3 dots in the Top-Right of the settings
  • reset App Preferences
next go into:
  • Settings
  • Storage
  • Clear the Cache
Finally, power cycle phone (turn it off and back on)
