I have two phones, #1 phone has 400 MB Data, and #2 phone has 1 GB Data. I want it so #1 phone the 1 GB Data and #2 phone has the 400 MB.
Why not just swap the sim cards? I assume the rest of the plan features such as minutes etc are similar. If you don't wish to do that, you could change the rate plan for your #1 phone plan for one with a higher data option, and your #2 phone to one with a lower data option. The rest of the features should be pretty much the same. Koodo also has some nice promotional plans going on now which might even be a better bang for your buck compared to the plans you are currently on.
Fareed Abulrob wrote:
Why not just swap the sim cards? I assume the rest of the plan features such as minutes etc are s...
Thank you!
