i have a samsung on5 need to connect to blue tooth head sets
i have the phone and i have 2 radio station apps i can hear the apps but if i plug in the ear pc the phone just tells me it is for the phone calls. i don't want to get head phones if they are not going to work. the apps are my tuner free and next radio apps. plus iheart and none let that ear pc work. seems it should connect to the ear pc for half the sound but it will not. i looked in the settings in bluetooth and all i have is phone answer on or off.
Hi Bob, you should go into your settings and look for a setting that automatically chooses a default action when you plug in your headphones. I don't have my Samsung on me right now but maybe someone else will chime in with the exact place in tbr settings where it can be found if you cant find it. Check if there's a smart settings section
Is this a bluetooth device or a wired one?  If a single bluetooth earpiece, it may well only connect as a phone device.
My wired headset connect to my Samsung without difficulty.
