I have a Nexus 4, - 4.2.2 Koodo phone and i am unable to connect to WiFi
Koodo Nexus 4 4.2.2
Small list of trouble shooting for you to try Restart the phone Make sure the phone isn't in airplane mode Turn the modem off and back on Turn your Wifi on your phone off and on And if all else fails reset your device Hope this help let us know if none of the above helps
Todd wrote:
Small list of trouble shooting for you to try Restart the phone Make sure the phone isn't in...
Thank you Todd! I shall give your suggestions a try tomrrow when i'm thinking more clearly. Best regards.
If your router is a DLink, check their site to see if a firmware update is available for that model.
Thanks. Its a rental from my provider. A 2/1 combo. Internet and WiFi for computer combined..
Contact your provider, especially if it's a DLink, after trying the following:
Get out of the house a ways, go into airplane mode, the turn wifi back on. tap on the wifi lnk you normally use and choose "Forget". Go back home and reconnect from Ø.
It's more then likely not a dlink as dlink doesn't really have carrier supplied routers as far as I'm aware
Todd, i tried your suggestions and something worked! Now i have WiFi connection and can take care of my 'upgrades'. Thank you so much for your help. S.
