I had a phone fall in to the toilet am I steel going to be billed for my other phone.
(empty)
What do you mean by the other phone?
I need my other phone fixed it fell in the toilet it got water loge.
If you send it in to be fixed, chances are you'll have to pay for the repair. Water damage isn't something that's covered by the manufacturer warranty. You keep saying "other phone" what do you mean??
Check with koodo that may have warranty for this. there losts things what people won't tell you Go up to keyos just ask thim if there any warranty for funny or bad no no usey koodo don't offer Far as I know there no warranty but I hereby koodo Plsese injoy your day
Check with koodo that may have warranty for this. there losts things what people won't tell you ...Water damage isn't covered by warranty.
Check with koodo that may have warranty for this. there losts things what people won't tell you ...Thank you guss I was rong
Userlevel 4
Water damage isnt covered. You will have to buy another phone or you can try the old rice trick. Stick the phone in a bag of rice for a couple days. I have had to do this once or twice
