I forgot my passcode for my lock screen, and cannot get onto my phone. It keeps locking me out.
  • 12 May 2017
  • 623 views
(empty)
Is it a lock to the phone itself? Then you either need to remember your code, or factory reset it... what phone is it?
If you forgot the password to unlock your phone you can use titaniumtux's idea at the bottom of this thread:
https://community.koodomobile.com/koodo/topics/i-can-not-get-into-my-phone-i-use-a-fingerprint-and-f...
My daughter forget the code. How do I go about factory rest the phone?
What kind of phone does your daughter have?
iPhone: https://support.apple.com/en-ca/HT204306
Android: https://www.howtogeek.com/226942/what-to-do-if-you-forget-your-android-phone%E2%80%99s-pin-pattern-o...
If the locked device is iPhone, you can use iTunes or iCloud to bypass the screen lock. In case iTunes and iCloud can not work well, try an unlocking tool. You can google such a tool or try Joyoshare iPasscode Unlocker that I have ever used.
Suppose your locked phone is an Android device, it is better for you to search for a technical tool to unlock the lock screen.
Hope this can be of help to you.
If they haven't managed to unlock their phone in the two years since this was posted, I doubt they're trying anymore.
