I dropped my s4 and the screen from the lower bit got shattered. I got it in November of 2014. How much will they charge me to fix it
You can fix it yourself for about $15 or have someone else do it for about $50. http://www.amazon.ca/Samsung-Screen-Replacement-including-Microfiber/dp/B00DUR2GZM
Keep in mind that's only for the glass itself. If the screen is unresponsive as well, you'll also need the digitizer, which can cost around $100 or more. You could ask a repair shop around your area for a quote.
Jonathan I wrote:
Keep in mind that's only for the glass itself. If the screen is unresponsive as well, you'll also...
If I'm not mistaken, on an S4 the screen and digitizer are all one piece. Haven't done them myself so I'm not really sure if that's true. Here at Future Shop were charging $229 to replace them. Average is around $200 at other little mobile repair shops.
I know a friend of mine and it cost him $250 to fix his S5 screen when he sent it in through Koodo.
