I am having problems with one number and I want to forward them elsewhere, Any ideas anybody?
  • 30 October 2013
  • 10 views
I want to call forward one number to my voice mail Everything that I have looked at shows that Koodo has call forwarding set up for me to forward my number elsewhere, but not for me to transfer one paticular number somewhere else (as it is becoming annoying that this person keeps calling me I would like to transfer them and the call to la-la land at times), but unfortunately I need to see if what they are saying is ACTUALLY important so I want to forward to my voice mail. Is this possible to do?
Userlevel 4
Depending on your phone, there is a free app called Mr. Number. https://play.google.com/store/apps/details?id=com.mrnumber.blocker I find it works wonders. I love it.
Userlevel 2
Not sure what type of phone you have? [b]CDMA To Activate: *72 + area code + phone number + SEND To Deactivate: *720 + SEND Dial 1 + area code when forwarding to a long distance number. These customer procedures also work in our roaming partner coverage areas. [b]HSPA To Activate: *21* + phone number + # + SEND To Deactivate: #21# + SEND [b] On HSPA devices, call forwarding options can also be managed via the menu options on the device. Now, since you need to forward it to your voicemail. I recommend you to go tru the settings of your phone and enable it. Not sure that type of phone you have. Tell me and I will get you the steps!!!!
Userlevel 4
Not sure what type of phone you have? [b]CDMA To Activate: *72 + area code + phone number...None of that helps since he is not forwarding his own number. He wants a number harassing/annoying him to be forwarded to his voicemail.
Userlevel 2
Not sure what type of phone you have? [b]CDMA To Activate: *72 + area code + phone number...Yes tyler, I emphasized that at the end. Not sure what type of phone david had. It could be easy to block it from the settings on the phone. You know! Hopefully david has an smartphone.
Userlevel 4
Not sure what type of phone you have? [b]CDMA To Activate: *72 + area code + phone number...I was just referring to the "how to" for activating call forwarding. For the topic, all of that was pointless. Try to avoid posting information unrelated to the topic.
