Huawei P20 Pro Android update
  • 3 January 2020
  • 3 replies
  • 300 views
I bought a Huawei P20Pro from Koodo recently. I noticed it runs Android 8.0. Can it be upgraded to Android 9 or 10? If I select “System update” it only shows a upgrade to 8.1. I read some comments here on this Forum that People received a update several months ago.
There should have been a Dec.11 security update.
https://community.koodomobile.com/articles-by-koodo-232899/software-update-schedule-7790542
Also the P20Pro should have android 9 right now and in some places they already have android 10.  Im unsure of the Koodo status for Android 10 on the P20 Pro.
OS updates may need to be done sequentially.  But I am unsure as I always refrain from updating unless something isnt working well.
Dont fix what isnt broken, right?
Update to 8.1 and maybe then you’ll get the 9.0 update.
I did all the updates starting with 8.1 up to 9.1.0.  It downloaded a whole bunch of security patches as well.
Thanks.
