Huawei Honor 6 on Koodo?
  • 12 November 2014
  • 1 reply
  • 67 views
I am able to get a Huawei Honor 6 for a good price and don't know if it will be compatible with our networks. Anyone know if it would work on Koodo?
Best answer by Jonathan I 12 November 2014, 04:28
It will, but your coverage will be terrible. It's not designed for North American frequencies, according to GSMarena. You'd only get the 1900 band, which isn't as commonly used as the 850 band, so using a device with both is ideal. I highly recommend looking for a different device.
1 reply
