HTC ONE V PROBLEM
  • 13 September 2014
  • 2 replies
  • 5 views
I have an HTC one V and I took my sim card out and put it back in and now it won't work saying that the sim card is not detected what should I do
Tray to rest the phone
Make sure it's inserted the correct way and the back door is securely in place. A poor design feature of the One V is that part of the SIM contacts are on the door, so if it's not snapped in properly, it might not read your SIM. I also recommend upgrading your device. Not because Koodo needs more money from you but it's just to maintain a positive smartphone experience and the One V was less than stellar in providing that.
