HOW TO UNLOCK PATTERN LOCKED ALCATEL PHONE
ANDROID ALCATEL PATERN LOCKED
Did you forget your pattern? Usually you provided a backup password, try to enter that. If you forgot both, you will have to factory reset your Alcatel.
Sophia wrote:
Did you forget your pattern? Usually you provided a backup password, try to enter that. If you fo...
HOW  DO I GAIN ACCESS TO DO SO PATTERN IS NOT ACCEPTED
KNOW THE PATTERN IT WONT ACCEPT IT
HOW DO YOU DO THAT WHEN I CAN,T ACCESS OR UNLOCK TO GET ANY INFO
Could you possibly switch off your caps lock please? It's rather difficult to read all those capital letters, t.b.h.
Usually if you enter the wrong code a few times, a message will pop up asking if you'd like to log in with your backup password. What Alcatel phone do you have? You might want to read this information: http://visihow.com/How_to_unlock_a_alcatel_android_fone_when_its_patern_locked_showing..error_too_ma...
