How to retrieve network security key for mobile tethering
Hello. I am trying to connect my laptop to mobile hotspot but do not know where to get network security key from? No box appears when I turn on hotspot!! Help please!!!
Best answer by Dennis 13 May 2021, 21:34
When turn on your hotspot, you should be able to set the network name and password.
Check your settings>connections>mobile hotspotĀ
So what phone are you using to create the hotspot? Are you using a windows or max or Linux OS for your computer?
Usually you can find the password in the settings of your phone.
