How to remove data block?
  • 3 January 2015
  • 305 views
When I first got my phone I only had the talk and text plan, so I had data block put on. Now I have gotten a data plan; how do I remove data block?
Login to self-serve and go to "change/remove add-ons" and just remove it. It's considered an add-on like any other add-on feature that you can remove at any time
Sign into self serve, click on plans and add ons, click change add ons. Remove data block. Confirm changes. Done.
Forget it - I solved it. Self-serve, change add-ons....
Now some time salf service donest work properly os because of that call koodo is butter talking one and one with a prison yes safservice is faster but limited what you can do
Now some time salf service donest work properly os because of that call koodo is butter talking...Uh...come again?
