how to print textos
So I see you're using android.
Depending on the app you're using the answer may be as simple as pressing print or emailing the conversation to yourself for later printing.
I use Chomp which allows me to email the conversation to myself , I can then open the attachment and print it out.
You can use chomp too by grabbing it from the Google play store.
Also, you can check "Print Hammermill" from the google play store. I used this app for short conversation, but it was easy and worked well for me 🙂
I also can vouch for the above app^^ have used it before. You can print over wifi/cloud/Bluetooth or a USB cable. Which can make things a lot easier.
