How to mute Samsung S6 with volume keys?
I just bought a Samsung S6 and noticed that when the pressing the volume buttons on the left side of my phone, it'll either adjust the volume or bring to it Vibrate, but it doesn't mute it. I had an S3 and S4 and was able to mute it with the physical keys. Anyone know a trick around this or experience the same issue?
Does NONE PRIORITY ALL show up under the slider. Tap none which will shut all sounds and vibrations down (including the alarm)
With lollipop on all Samsung devices there is now no mute just what you explained you are experiencing
I don't see that option Chad- Looks like the only way to mute is by going into settings or pulling down the menu bar from the top and tapping it there. Thanks for letting me know of the change
