How to know which cellphone model works with Koodo?
  • 17 November 2014
  • 1 reply
  • 22 views
Hi! I have a old BB Bold, and the battery life is just ridiculous. So I'd like to change my phone. Can I change it for a cellphone that is not listed in the phones available with Tab from Koodo but the company of the phone is, but not the exact same model. What if my friend want to give me the Huawei Ascend Y530 unlocked. Can I use it with Koodo? Will I need to buy a new simcard? Thanks,
Best answer by Cameron Jones 17 November 2014, 14:42
Yes you can. As for using unlocked Huawei, all you have to do is slip in your exisiting SIM card to it. Check here for network compatibility http://help.koodomobile.com/getting-started-with-koodo/sim-cards-and-non-koodo-phones/how-do-i-know-if-my-phone-will-work-on-the-koodo-network
1 reply
