How long does it take to change phone numbers?
  • 5 July 2019
  • 2 replies
  • 1258 views
I recently moved provinces and went through the process to change my number to get a local area code. It had been a few hours, and now my phone has no service, but still has the old number under the 'My phone number' info in Status.
Did I mess up the process by having the Callback made to the phone whose number I was changing, and if so, what can I do to fix it? If not, how much longer should this take?
Best answer by Dennis 6 July 2019, 00:03
Restart your phone and see if that works.
Usually a number change takes 15 minutes
That both did and didn't work. Once I restarted I had a voice mail that I apparently got right after being disconnected. It's resolved now, Thanks!
