How do I text on my Nexus S? Many thanks in advance>
The same way you would text on any other android phone?
Thanks Timo. But I have never texted before. Honest!
tap on applications icon (block made up of 16 squares) find the one for messaging, should look like a speech bubble with a smiley face. tap new message choose a contact to send a message to or enter a number to send a message to tap in the box where it says type to compose type your message tap send the message should be sent wait for a response. That should be about it. Apologies if some of the instructions don't exactly match what you see, the emulator I have for the nexus s is about 2 os versions behind.
I think I have got it. Thanks for your patience, Timo. You have also indirectly clarified my confusions.
I'm not a big fan of the stock Nexus Messaging App. I'd recommend Sliding Messaging from the Play Store--> https://play.google.com/store/apps/details?id=com.klinker.android.messaging_donate
