How do I tell if a model of phone will work with Koodo before buying it?
  • 7 April 2019
  • 4 replies
  • 923 views
It seems like the only way I can find to identify if a phone will work on Koodo is to have the IMEI id but I would prefer to know BEFORE I buy a phone if it will work with Koodo or not.
I am looking at getting a Samsung Galaxy S10e international version with the Exynos chip (not snapdragon like the one that Koodo sells) and I wanted to make sure that it would work with Koodo since I know some times specific versions of phones can't pick up on every carrier's network depending on what country you're in.
Best answer by Dennis 7 April 2019, 20:56
https://www.gsmarena.com/samsung_galaxy_s10e-9537.php
https://www.koodomobile.com/help/my-phone-compatible-koodo
Check to make sure the phone you're looking to get works on these frequencies below
These are the frequencies Koodo is currently using
4G LTE and LTE Advanced:
2100 MHz downlink and 1700 MHz uplink (AWS)
1900 MHz
700 MHz
850 MHz
WCDMA :850 MHz and 1900 MHz (UMTS)
CDMA: 850 MHz and 1900 MHz
You can often check phone compatibility at willmyphonework.net as well, although the s10 series is not listed just yet.
Thank you all for the responses. I appreciate it.
