how do I send & receive picture to text?
What have you tried so far.
Have just tried to send it & receive not very tech savy
Do I need to enable data.....if I do will I be charged extra
Yes data needs to be on.If you have wifi, connect to wifi first and then turn your data on. That way data will only be used to send and receive the pictures. Make sure to remember to turn it off before wandering out of wifi range.
Will I be charged for the data?
If you're connected to wifi before your turn on the data then you shouldn't be charged.
If you are connected to a wifi network: NO you will be not charged for data, but the moment you leave the connection your data will be live and active (if you plan has data enabled)
Exactly
Thank you everyone
do you mean a picture of text?
I mean a picture taken with my phone cameras and adding a few words.
Userlevel 3
Hi Helen, because this thread is a year old and marked answered and the fact that you asked your question 6 hours ago without an answer from one of the MM's, I would suggest that you go to the top of this page where it says New Post and ask your question again.
