How do I retrieve a blocked picture text AFTER I unblock data?
  • 10 December 2014
  • 1 reply
  • 35 views
A friend sent me a picture text last month which was blocked. I understand why it happened but is there a way to retrieve it after I unblock data on my cell? Thanks for any help PS I haven't deleted the text yet, I just can't open it
Best answer by Paul Deschamps 10 December 2014, 08:24
Chances are it won't be able to be retrieved Unfourtunatley, the only thing you can do is tap on it if it says download and keep your fingers crossed. If you've done that then I think your SOL. Oh and make sure data is enabled in your phones settings as well.
1 reply
