how do i get rid of my incoming or outgoing calls?
Best answer by Paul Deschamps 20 October 2014, 15:48
If you mean from your call logs then tap on your dialer and then go to your call logs. Then tap the menu button and select to delete call history. The menu button may be on the phone or 3 dots in the corner of the screen.
1 reply
