How do I enable multiple users in android 8?
The "Users & Accounts" option is only listed as "Accounts", and there's just no option to enable any other users on my phone. Did koodo block this function?
Cell: LG G5
Android: 8.0.0 ( H83130C, Kernel 3.18.71 )
Best answer by Mats 7 January 2019, 05:02
It seems that LG has removed this for the G5
https://forums.fido.ca/t5/forums/forumtopicpage/board-id/Smartphones/thread-id/35236
I don't believe that Android has a multiple use option like a pc for logging into to different user profiles.
Accounts would be your various accounts you use for email, Facebook, cloud, etc
You're wrong about that, Dennis.
https://www.bestusefultips.com/create-user-account-in-android-oreo/
Try this
I appreciate that you've made an effort here Dennis, but please fully read my original post carefully.
At this point I may need to reset or restore but I want to avoid that if at all possible.
I doubt koodo has blocked this option.
You might want to do a more Exhaustive google search and maybe checking reddit or vda or other forums
