How do I block unwanted text messages and phone calls
Which device do you have? Newer Androids (specifically the S III in this example) have a blocking mode built into the OS, which allows you to blacklist numbers you don't want to deal with. There may also be an app available... after a quick search, I found this: https://play.google.com/store/apps/details?id=com.mrnumber.blocker&hl=en If you have an iPhone then search your app store for something similar.
I'd recommend Call Control or Extreme Call Blocker from the Google Play Store.
its an Android .90
how do i block call from my blackberry phone
Hey  Dianne! Can you please confirm which BlackBerry model you have 🙂?
I have a moto g (3rd generation).  How do I block unwanted calls?  I have tried adding them to contacts but don't get an option to block.  Thank you.
Go to your phone app, hit the three dots in the top right, Call Settings, Call Blocking, Blocked Numbers.
If the number has called you already simply go to your call logs, tap and hold on the number and click block number.
How do I stop a rejected caller from leaving a message on my voicemail?
There is no need to ask the same question in multiple threads; it will get answered asking just once.
You can use third party iOS app to block spam calls. I found some application to stop spam calls just like TrueCaller, Look UP, Nomorobo and more application and without app how to stop spam call on iPhone read this thread: https://www.howtoisolve.com/how-block-spam-phone-calls-ios-11-iphone/
