How do I block a number completely from both messaging and calling on a Samsung Galaxy Ace? My phone does not allow me to manually do so.
  • 22 April 2015
  • 2 replies
  • 29 views
Someone I know is harassing me and I would like to block their number completely. I use a Samsung Galaxy Ace and my phone does not allow me to manually block numbers. Do I need to call to have this done?
Fido has this, but I don't see koodo offering it. Maybe they should. You can use some of te record here though: http://www.digitaltrends.com/mobile/how-to-block-phone-calls-on-your-android-smartphone/
Hi Emily, The Samsung Galaxy Ace does not support SMS/Call blacklisting on its own, you can take a look at what is available on the google play store though. Their are a bunch of applications that can do that for you, just by quickly searching I found this one here: https://play.google.com/store/apps/details?id=com.ekaisar.android.eb Take a look at it and other apps, find one that works for you and that is compatible with the phone! Hope this helps!
