How can I match my credit card with my address, as this is not allowing me to pay with my credit card for pré authorized. payment.
Is there à way to correct this issue with my credit card. Maybe to reset my info?
Is your credit card bill going to a different address than the address we have on file for you William?  If yes, I believe you would have to update your address with your credit card issuer.
Just give your Credit card company a call to change your address to the same one you use on file with Koodo. Thats the only way you can use a credit card to make payments. OR if your credit card is the correct address that your currently living at, and Koodo has an old one, give Koodo a call to update your address to match the one on the credit card.
