Hi there question . if i have my own phone , can i still keep my old plan grandfathered plan?
retaining an old plan
Yes. If you are making any account changes there is no reason that you would be switched off it. Or are you trying to do something?
The only time you cannot is at some threshold of grandfathered you can only use tab small to get a phone through Koodo.
Absolutely just update the IMEI from the new phone on your Koodo account!
That is not necessary and hasn't been since the CDMA days. Getting another phone is just putting your sim card in it like any other provider.
