hi,i have question about roaming. i am going to calgary and right now i am in sudbury . so if i go in calgary will i get charged for roaming
hi,
There are no Roaming Charges in while you're in Canada
If you have a canada wide plan then you wont get charged for Long distance receiving calls while in Calgary either
No worries there no long distance you see that won't telling you about long distance after 5:00pm during the day here cut your bill this is viop this way you can call at any time LTE usege just be quick this way no charge only uses 500mb you will lost of data here website www.fongo.com rade it up sine up for free free call display free call forwarding free conference call
I'm ikaros fan wrote:
No worries there no long distance you see that won't telling you about long distance after 5:00pm...
There are NO roaming charges in Canada.
Yes you are right but before 5:00pm it will against your minutes this is way I gave the website Koodo dose not offer free call forward fongo dose offer this look www.fongo.com you will see thank you
