Hi, I had to change phone and wifi is working fine and calls and text but no the data, what could it be? Pls help
I had to change phone from blackberry to acer and wifi is working fine and calls and text but no the data  I just restarted the phone  and turned off a wifi and is the same, no data at all, it says not connected.
You may have to manually configure the APN settings Settings....wireless and networks... mobile networks....access point names See if "Koodo.sp" is selected and or available If not you'll have to create it
Check if your APN settings are correct, Maylin. You can find the correct settings here: http://aide.koodomobile.com/plans-add-ons-data-and-other-services/data-on-android/How-do-I-setup-dat...
Sophia wrote:
Check if your APN settings are correct, Maylin. You can find the correct settings here: [url...
Thank you both, yes I had to configure it manually but now is working!! Thank you soooo much!
