Help With Koodo Network Questioins
Will this phone work on the koodo network? Everybody gives different answers as to which frequencies are supported so I would just like to double check before I make a purchase because I already bought one phone that doesn't work on koodo. Here's the link: http://hdcmobile.com/review/product/list/id/736/category/3/
Userlevel 4
HSPA 850/1900 MHZ frequencies are what Koodo uses. I have not seen different answers for this.
Koodo uses: 3G HSPA+ 850/1900 4G LTE 1700/2100 This phone uses (http://hdcmobile.com/hdc-galaxy-s4-legend.html): Network Band: GSM 850/900/1800/1900 MHz + WCDMA 850/2100MHz So it has only one of the 3G bands which is not ideal. I do not recommend getting this phone for use on Koodo
