HELP verizon s4 cellular data
Verizon handset may not be compatible with Koodo network. They still use CDMA technology which has been phased out in most of urban Canada.
From the specs, as long as the Sim slot is unlocked, you may be able to use this device. Does the phone part work with a koodo Sim inserted? Goto Settings...wireless and networks....more....mobile networks....access point names Make sure your APN is setup correctly, if not then you'll need to add it.
