HELP please, Sim card and Nexus S don't like each other
I have a Nexus S 4.0.4, since a couples of weeks the service goes out and it say "No SIM card" even do there's one in it.I tried to take it out and put it back in but it doesn't always work and kills the batteries as i sometime need to close and open my phone often for it to work... Am I the only on with this problem and what can i do?
Userlevel 2
Here's what you do. You take them both, sit them down and talk it out. Ok, I'm kidding. If the phone isn't recognizing the sim card, then you have 1 of 2 issues. It's either the sim card or the phone. Try another sim card. If the phone doesn't recognize the 2nd sim card(as in you get the same message), then it's the phone.
The problem is either with the sim or the phone. Try changing the sim and see if the problem goes away.
Userlevel 2
Timo Tuokkola wrote:
The problem is either with the sim or the phone. Try changing the sim and see if the problem goe...
Go to sleep 😛.
