help please
  • 9 February 2015
  • 2 replies
  • 65 views
I have a samsung s4 and it is turned on and I hear it ringing or notifications sounds but my screen stays black
Best answer by Philosoraptor 9 February 2015, 19:29
Try removing the battery and powering it back on. If the screen does not respond at all, then it's likely dead. If you purchased this phone less than a year ago, it would still be under warranty and you would then want to contact customer service or take it to your nearest Koodo kiosk.
you're probably SOL I bet the Koodo warranty is useless
