HELP ME..MY VOICEMAIL NUMBER GOT ERASED!!
  • 5 September 2013
  • 3 replies
  • 4580 views
My Android Samsung Galaxy has erased my voicemail number and replaced with another person's phone no.? Please help me..I need step by step instructions to find my voicemail phone number and re-set Please!
Open up your menu in your phone dialer (three dots in the corner). You'll be able to find voicemail settings there. Your voicemail number is 1+your area code+your phone#.
Timo has a good answer here http://community.koodomobile.com/koodo/topics/voice_mail_box_number
The koodo vm access number should be listed as something similar to +16475804001. There are multiple different numbers depending on which voicemail server you are assigned to, but most end with 4001, 4002 or 4003. If this looks like the number programmed into the phone, don't change it until you test the voicemail.
