Help, I'm stuck on telus 3G.
Switched from telus pre paid to Koodo pre paied, still says my provider is telus and my data is not working. I'm able to text though.
You don't have to worry about it saying Telus... I often get that as well. As for data, did you add a data booster and have you checked your APN settings? http://help.koodomobile.com/plans-add-ons-data-and-other-services/data/how-do-i-setup-data-on-my-non-koodo-phone
I'm on android and the page is missing for Android instructions.
Here ya go: http://aide.koodomobile.com/plans-add-ons-data-and-other-services/data-on-android/How-do-I-setup-dat...
Thanks! Oneplus actually had me covered, it was pre set! Took some fiddling though.
So you have data now? Sometimes it takes a reboot too, but glad you got it all sorted 🙂
