help!asap!voicemail issue!
How do I change my voicemail from French to english I haven't set it up because I can't understand help?
I think you'll have to call customer service to get that fixed. They're closed across most of eastern Canada but if you're out west you can try calling them now? 1-866-995-6636
I am going to agree with Johnny on this one it need's to be done by costumer service.
Hi Paige, here is how to set the language for your Voicemail. Call your Voicemail and enter your password. Then select option #4 (Personal options), then option #5 (language options) and finally option #1 (Owner Menu Language). Hope it helps! ________________________ If you see a good answer, give it a star.
Yannick wrote:
Hi Paige, here is how to set the language for your Voicemail. Call your Voicemail and enter your ...
That's good to know!
