Going to South Africa on business for 2 weeks - what will I need to add on to my service?
Currently using Canada-wide unlimited
Hello Nathalie
What are your needs? Data, minutes, texts?
Hi Nathalie,
You can go and not use any add-ons but you would pay a pay-per-use rate. Take a look at the international roaming add-ons available here and see which one fits your needs best.
You will need to add pay per use international lon distance. Which is a free add-on in self-serve. Then there is voice international roaming and if you want data you will need to add data international roaming. Then you can decide if you want to use the roaming package or go pay per use as per the link Mathieu provided.
