GOING TO CUBA IN SEPTEMBER /WHAT WILL IT COST TO TEXT TO CANADA FROM CUBA AND HOW DO I PAY FOR IT
SAMSUNG S6 EDGE I HAVE A MONTHLY PLAN FOR MYSELF AND MY WIFE
Start here:
http://help.koodomobile.com/coverage-long-distance-and-travelling/travelling
You can choose from a few add-ons or do pay-as-you-go.
Please read and follow the instructions carefully: you have to activate roaming in your account since overseas connections are by default blocked to avoid expensive $urprise$. If you are ordering by texting, do that while you are still in Canada and on the day that you are leaving.
The cost will be included in your bill. It could be delayed depending on the carrier roaming partner reporting what was used but it shouldn't be. You also have the option to rent a Cubacel Sim card at any ETECSA office, which is also found at major airports in Cuba.
Goran wrote:
The cost will be included in your bill. It could be delayed depending on the carrier roaming part...
Note that if you do obtain a local sim card you phone will need to be unlocked first.
