Galaxy s6 battery port
samsung galaxy s6. The phone charger is loose and the only way to solve it is to keep buying a new charger which is not economical or environmental concious. Any thoughts? I had a galaxy s4 previously and had the same problem and it almost caught fire. I contacted Samsung, it was painful.
Best answer by Chad Burr 25 November 2016, 08:16
Your only other option would be to pay an authorized service center to fix the charge port. that will ensure your warranty (if you still have one) remains intact. If you don't have a warranty anymore then take it to any fixing shop and have the charge port replaced. This way you're not putting any more strain on the environment.
1 reply
