Galaxy S2X Jelly Bean Update - Battery issue
I have recently updated my GS2X to Jelly Bean 4.1.2 and have noticed a slight issue. Whenever the phone is "charged" it goes from saying 100% on the battery indicator (when battery percentage is displayed) to 98% I don't know if this is a known problem or what. I am wondering if I should let the phone die down completely and fully charge it. Please let me know if there is a solution to this issue.
Try doing a battery pull (take your battery out while the phone is on and leave it out for two minutes) After that, leave it run for a bit and go into settings/battery and see what it using up your battery. I wouldn't worry about the 2 %. My samsung captivate used to do that all the time. It would charge to 100% and then actually discharge to 90% (display would show 100% until I disconnected the charger, then immediately show between 90-98%)
Somebody else had the same exact situation. You'll find the solution here: http://community.koodomobile.com/koodo/topics/siix_jelly_bean_update_problem_experiencing_longer_recharge_time "Cristhian Mejia 4 days ago I actually resolved my issue. Charge phone while off, then turn phone on. After not phone will show 97-98% download battery stat eraser, Néma's app works well, run it regardless the battery being 100% or not and turn phone off. Let charge to 100% re-power phone and let charge. This time you should get a 100% icon and to disconnect phone from charger icon like in ICS. Now battery charge state behaving like ICS."
Can somebody help me to update mine? I cannot figure it out for the life of me! please help!
Userlevel 2
What are you having trouble updating Nicole? ________________________ If you see a good answer, give it a star.
I cant update the kies....it says there is one but when i click the update, it stops at 19% than just closes....i think ill have to contact samsung support....is the jb update available now for the s2x?
Userlevel 2
Nicole Diaz wrote:
I cant update the kies....it says there is one but when i click the update, it stops at 19% than ...
The Jellybean update is available for the Samsung Galaxy S2X. ________________________ If you see a good answer, give it a star.
how long is the update suppose to take? my phone had been downloading for about 4 hrs now!! Is this normal?
Shalicia Harris wrote:
how long is the update suppose to take? my phone had been downloading for about 4 hrs now!! Is th...
Mine took about half hour....
Should take 26 minutes from start to finish.
Wow! Kinda reminds me of the days when the Motorola MicroTAC 9800X reigned supreme, lol! One thing though, upgrading to the battery (shown above) will likely mean you'll lose NFC or near field communication ability. The NFC chip is built right into the stock battery of the S2x.
